Yeah abuse will always prevail. Change your driving habits and the track bar will be just fine. Common sense will save you a few bucks.I just drive the hell out of it, this one bent down towards the diff, the other bent towards the floor board. Did i Mention i am running 500Hp and abuse the dog snot out of my jeep? Yesterday I also ripped the upper control arm Mount off the rear diff. I do not think it is a matter of doing something wrong but driving it like I stole it 4 days ago and trying not to get caught. :clap2:![]()
I wouldn't say it is a lack of common sense. It is a matter of using the jeep to its fullest potential which I do. I was mainly wondering if any one else has had this problem and if so what was the fix that worked for them. I rock crawl and prerun this jeep. So I do use it for the best of both worlds.
Sounds like you found your Jeep's "fullest potential" so replace the track bar with an OEM, dial back your enthusiasm a notch, and you should be fine.
That was my thought. Once things begin to bend or break its gone past it's fullest potential..haha. Build it like EVO 1, problem solved.
Obviously Mel doesn't wheel as hard as you do.They guys at Evo tell me they are running a factory rear Trac bar. I just have a hard time seeing that. Unless Mel carries several spares and changes them regularly.
I'm fucking with you, brother.I am not saying that Mel doesn't wheel hard. I also am.not saying that I wheel easy. I am looking for a solution, I just made a statement that I called them and they told me to stick with a stock track bar.
I guess I try to be more sensitive when saying the same thing. Stupid government sensitivity training has got me all messed up..haha.Wheeling hard and wheeling like an asshole are not be same thing. It is clear which category you fall in.
Try the teraflex adjustable rear track bar.
