Samuelh3
I was doing some work on my control arms. As some of you might recall I had my EVO arms backwards. I measured the distance from the base of the Jonnie Joint to the control arm loosened it all the way until it fit in the mount and started righting things down to get it down the the correct length. I started on the drivers side and had the driver tire up with the passenger tire down. The passenger side control arm was about 1-1.5” longer than it needed to be.
As I was tightening the control arm I heard a loud ping and didn’t think much of it as I thought the suspension was just settling. As I went over to the passenger side I suddenly notice diff fluid leaking from the axle tube.
What the heck did I break? Did I over twist the axle? Freaking out a bit here.
