That’s BS. You’re better off using sea foam spray in the throttle body every so often to clean out carbon if need be. All the high octane gas does is keeps the engine from knocking or pinging because it has a much higher detonation temp, as others mentioned. Stick with 87 octane.
That said, my ‘07 has 167,000 miles and still runs great. I do have pinging every so often and run a can of sea foam spray through the intake which knocks it out for a while.
Learn how to do repairs yourself which will save a ton of money. I always trust my own work more than what most shops will do, especially with the wealth of knowledge in forums like this. You won’t find that with most other vehicles.
Sent from my iPhone using
WAYALIFE mobile app
