Yeah those look like the updated ones. The old ones had equal lengths on both sides. What did you not like about yours? I'm guessing noisy
Sent from my SAMSUNG-SM-G891A using Tapatalk
Noise, some coil sway “s shape” and fit. They trapped a lot of sand in between the shock and slider. The AGM’s seam to have a tighter tolerance.
Thanks ORE!
Big week of upgrades here! I just picked up the Jeep from Offroad Evolution.
New PR44/60s installed with 5.13 gears
ARB lockers front and rear
37” Nitto Ridge Grapplers on 17” KMC Machete Beadlocks
EVO rear Rock Star shock/lower control arm brackets
J.E. Reel 1350 front and rear drive shafts
I Trimmed my fenders over the weekend, but some clean up still required.
Big thanks to Drew and the Offroad Evolution team for the great work (as always!) and for taking care of every detail.
[emoji1360]. Bet you’re itchin’ to hit the trails with your new set up. Enjoy!
Something is wrong with this thing.
Mine ended up being the purge valve which is located right next to the battery. It happened while I was changing the battery out, I bumped into the valve with the battery as I was setting it and put a hairline crack in it. I had zero idea I had done it but a month later when I figured it out that was the only thing I could think of.
The hoses that attach to that valve and also run throughout the rest of the crap system are susceptible to pinhole leaks though. If you run your fingers along them and feel rough spots it's a decent indication that there might be a small leak. That's the cheapest and easiest place to start to try and get the code cleared.
Don't know if this will help just figured I'd share what happened to me
Next to the battery huh? I’ll give it a look. Thanks.
