Zone offroad 3 inch lift
jiggawhatpolo
I bought this lift for my 2010 2-door JK. Now I am reading that I will need 1.5 wheel spacers. I have the 17 inch rims. Is this true?
Sent from my SCH-I535 using WAYALIFE mobile app
Depends on what size tire you will be running and if you will be installing them on your factory wheels.
if your still running the stock rims then yes you will. i would suggest 1.5" spacers from spidertrax. if your not running stock wheels you will need to make sure they are at least 4.5" backspacing or less
Ok have a question for all of you. I have the life installed. Now want yo upgrade my tires to 35's. Can I use my stock rims with spacers. And what size tires do I need to get. Have the 17 " stock tires. Thanks
yes you can run a 35 on stock rim. all you need is a set of spidertrax 1.5" wheel spacers and your good to go.
