The new shoes are on! :rock:
Thanks. The Jeep was black originally. I had it Line-X'd in Mojave Sand.
Does the linex hold up well? What did they charge you? I have been wanting to do this for a while. Also did the do the door Jams and inside the hood area?
Looks great.
Everything is done in Line-X except the engine bay. Didn't want to pull the engine. The underside of the hood is done though. It's been done for about 6 months and looks brand new. The inside of the tub is done in black. All the door jams are done with great transitions from the Mojave Sand to Black. They also had to paint some areas where the trim pieces attach since the Jeep was originally black. They actually only charged me $7K including the custom work to do the lettering on the hood and to smooth out the rear corner armor. Of course they said they'd never do one like this again for less than $10K once they saw how much work it was to do mine.
Switch-pros install. Put the push button module on the RH cage.
Sent from my iPhone using Tapatalk Pro
Upgraded my suspension from A 2.5 budget boost to 2.5 coil lift. I netted a tad more lift but I am sure once it has had a chance to settle it will be a tad closer. Ride does feel a bit smoother. Still have to find time to get the lower control arms and extended brake lines done.
Before
After
Regeared. I recommend it! [emoji1303] I have an automatic transmission, and went with 4.88, with my 315/70r17 tires,
Dig it! I think my build list just got l I nger![emoji85]View attachment 249803
Compressor installed.
Switch placement.
Running the air line.
What parts did you use to hang them? Can't quite tell what that isAdded DIY door hangers to the garage wall:
More here:
http://wayalife.com/showpost.php?p=870199
More here:
