Nothing really exiting but I did plastidip the jeep emblem and removed the stock exhaust then put it back on, probably going to wait till I have the funds to buy an exhaustImageUploadedByWAYALIFE1445550471.951247.jpg
Installed S Pod. Pair of KC LZR led pilar lights. Looking forward to adding a few more lights and adding rockers from OTRATTW. ImageUploadedByWAYALIFE1445647287.895807.jpgImageUploadedByWAYALIFE1445647312.564590.jpgImageUploadedByWAYALIFE1445647322.513997.jpg
Installed a Poison Spyder rear bumper/tire carrier/high lift mount. Just need the plug for the license plate and some lights. I didn't think that far ahead, lol. ImageUploadedByWAYALIFE1445658581.630595.jpg
I made a trunk shelf for my 2 Dr! Help make some of that vertical space more usuable. And it is easily removable of need be.
Where'd you get the mount for the light bar? I've been looking around but not sure if I found the right one. Thanks in advance
To be honest I got the light bar off amazon (cheaper light bad) and I just drilled some holes through the bumper and just mounted it using the bolts that came with the bar ImageUploadedByWAYALIFE1445703495.210624.jpg
It's hard to see but just little brackets that hold it up
Looks like my pictures didn't go through.
So let's try again.
Installed the R2C Cold Air Intake on Rocktrooper. Having the option to swap out filters for daily driving and severe off-road conditions was a win. The fact that I also had seen an improvement in MPG was a huge bonus!
https://www.youtube.com/watch?v=xWZumq0XWDc
Any questions, let me know. I'd be happy to answer what I can.
Can you not change the factory filter for daily driving and severe offroad conditions?
Are you asking if I could leave the factory air on and change out the OEM filter with another filter, like a drop in K&N filter? If so, I actually had been doing that. I would replace with a K&N when I took it off-road and then pulled it and put the factory back in when I was done. What I did notice is that in the factory air box I was seeing dirt internally in the box and you'll notice in the video there is actually some dirt in the throttle body. I wanted to get something better to protect the engine. I really only drive the Jeep when I take it to go off-roaring.
Or
Are you asking if there is a permanent filter solution so that you could not switch out filters? If so, I don't know. I think R2Cs item is that you are able to swap out for even better protection when off-road. Beyond that I could not say, you may want to see if you can e-mail or call them to see if they make a different setup.
Let me know if this did not answer your question.
OBA, Switch Pro, and some nice grab handles
Just placed my order! Does anyone have a good install thread for ORE rockskin corners? I've had a hard time finding one and Also got the ORE hood decals! Should look badass! ImageUploadedByWAYALIFE1445810163.575736.jpgImageUploadedByWAYALIFE1445810173.075389.jpg
