What size bolt? Please help
That's a nut on the drag link. The bolt is actually apart of the drag link it's self. Are the threads on it messed up?
The nut had to be cut off, threads on the stud are all good, just need the nut
The bolt had to be cut off, threads on the stud are all good, just need the bolt
Unfortunately I don't think the bolt its self is replaceable. You need to get a new oem drag link. You can get one from crown for around $70 I think
M10x1.50
http://www.quadratec.com/products/56014_1007.htm
Its actually a m14 1.5, I was able to find a normal nut but not sure of the grade, still searching for it in grade 8 but no local parts stores stock it, any ideas of where to look?
Here's all the m14 x 1.5 grade 8
Nuts
https://www.fastenal.com/products/fasteners/nuts/hex-nuts?r=~%7Ccategoryl1:%22600000%20Fasteners%22%7C~%20~%7Ccategoryl2:%22600072%20Nuts%22%7C~%20~%7Ccategoryl3:%22608621%20Hex%20Nuts%22%7C~%20~%7Csattr03:%5EMetric$%7C~%20~%7Cattrdiameter:122900%7C~%20~%7Csattr05:%5E1.5$%7C~%20~%7Csattr07:%5E%22Class%208%22$%7C~
