VIDEO : RAMPAGE Trailview Fastback Soft Top for a Jeep JL Wrangler 4-Door
Elroy231
Sure is a great look. I did have a few questions but in reading thru the thread they have been answered. This top compliments that jeep well, just my 2 cents.
Here are a couple of pics of what the clamps should look like when installed. Please note that they do in fact go over the OE brackets. This allows the windshield header channel to sit tighter against the windshield rubber seal.
Here's a shot from above.
Rottenlv
so I installed this top today and I'm getting a ton of wind noise, and whistling coming from the front corners of the top. here are some picture from where I have pinpointed the noise. Did I install this properly as it doesn't look like it sits flush and you can see the gap that's making all the noise on both sides. any help or ideas would be great as the top is amazing other then this.
I get wind noise from those areas too. Being that the Trektops that I've run on my other Jeeps made a lot of noise too, I never gave it too much thought but looking at mine now, I can see what you're talking about. I think I might try to add some weather stripping there to see if it helps.
Rottenlv
I'm noticing now at speeds above 70 mph the top is lifting and I can see light between the top and were it meets the windshield. Same as you described, I did install the latch over the original. Was there something different about the new latch rampage sent you?
