RockingK
X2, could joy have said it better
Not fat fingers and spell check on a smart device... hmmm
Thanks for posting, great info and this is your stock baseline I guess.
Interesting on the from axle housing of the M210, they moved the drain plug to the bottom of the housing. On the rear, is it on the side like the JK D44? Just curious.
That’s good intel, thanks for using your JL as a guinea pig. Sounds like the 2” lift and 35” tires will be a good choice. Some of those skid bars will be prime aftermarket parts once the stock hollow ones get crushed.
Thanks for the follow up!
JT
Everything held up well for what it was. That said, you have more experience than most.
What are some of the first skid upgrades you'd like to see, besides one to protect the trans lines. Couple of those crossbars seem suspect? And the bolts on the bottom of the frame rail?
Jet Li looks beat up at first, but always comes back stronger.
I want that garage!
I was looking forward to this video. Well done. And it looks like he did as expected. Although I can’t help as to wonder how the outcome would have been if you already had a lift and those new shoes on.
Looks like all the factory skids did what they were designed to do. It really did sound a lot worse, you didn’t use a stunt double for Jet Li did you?
:cheesy: Thanks
If we had a lift and bigger tires, I would have just taken BIGGER lines :yup:
Thanks for confirmation. Small details but great to add to the knowledge base. [emoji41][emoji1303] I guess there is always a bigger rock. [emoji1320]
X2
