Transmission fluid change
DMF
I search everywhere on the net and couldn't find anything for a 2014 Wrangler on changing the trans fluid/filter so I assumed they were all the same regardless of what year. Well when I remove my skids I got this. Am I suppose to remove this too? Some internet searching said its all flushes now. Any help would be great!ImageUploadedByWAYALIFE1462642888.595565.jpg
Yea remove the cross member but mine looks different on a 13. I tried to change it with the cross member on and it didn't work. Then drop the pan and make a huge mess, I used a kiddie pool to collect the carnage.
Just to confirm, remove this cover with the torque bolt will reveal the trans pan.
The trans pan is that beige pan, it won't clear past the cross member in your way because the oil filter sits down low. Once you loosen those torx bolts you're going to leak a ton of oil. There isn't a drain spout for whatever reason, it's a messy job.
Thx Drunic. Think I'll button everything back up and call the dealer and have them take care of this. Don't think I want 5qtz of ATF on my drive way. TY for your help
Glad to help, I couldn't find any real walk through on it either. Filling it up is a guessing game too, just not a good design.
Also you have nearly a quart in the torque converter and a bit in the radiator an lines.
Every video and walk through I looked at, the pan look different. Mine looks like it's only a cover and it didn't look like I would be able to remove the cover with my cross pipe in the way. There was only torque bolts holding that beige pan up and next to each torque bolt there was a fastener holds the pan\cover down like an air box. But anyways thanks again for the help guys.
