Trail Raider Photo Diary/Build Thread
Well, it's not the CLEANEST fix, but it's sealed and no longer puffin like a diesel like it has been since I did the long arm.
Also went a head and threw on the dynomax stuff. Essentially the "quiet crawler"
sent from SPACE!
DZZ Build thread
Looks good bud. Bummed I didn't get to see it in person, so you gotta fix that!
How's the sound? I'd love to clean up the underneath of mine, but don't want to sound like a riced out Civic.
Sounds great! Can barely hear it while cruising around, but still comes alive over ~3k rpms... it's perfectly quite for crusing at 75 mph, but still makes a bit of noise when under load. I like it :thumb:
sent from SPACE!
DZZ Build thread
Went through the jeep and did some maintenance today.
Finally got my Johnny joints to take some grease, used Eddie's trick of backing out the zerks a little... and what do you know, they took.
Found this little mishap on the passenger rear lower. Not sure how that happened but luckily, I was still able to grease it.
Also greased both drivelines, did a tire rotation, did an oil change and installed my WFO Concepts Extreme tierod.
Because of the PSC using a 5/8" heim joint and the massive 2" OD tierod,I had to make my own clamp for it. but sadly, the pics are on my other SD card. so I'll have to upload them later if I remember... all in all, it was a great Sunday!
sent from SPACE!
DZZ Build thread
Here is a side by side of the factory tierod next to the new, MASSIVE WFO Concepts Extreme tierod.
Thank you, Exodus Jeeps.
sent from SPACE!
DZZ Build thread
I think I'm going to get that tie rod if mine ever fails or gets damaged too much. It's huge.
Finally made it out to trees ranch, Awesome place! Thanks to Flat top for the pics! :thumb:
Lets do this
Benito getting a little close to the body after sliding a bit too far passenger.
