Traction control?
Emptybrass
How can you COMPLETELY disable it? Turning it off just makes sort of a delay. I getting my tax return soon and want to get arb lockers f&r but this seems to put a damper on my goals. If I can't then I'm thinking a 3.5" lift of some sort.
The switch will work on a 2013. I have mine installed on my 2012. The steering wheel trick will not work on 2012, and up. The switch will even work on 2014.
I believe when you press the button below the HVAC controls, it does disable the ESP, but the rollover mitigation works off of the ESP as well. I found out that with the button pressed I could still do doughnuts in the snow. It just seemed like if I was trying to do a high speed slide it would activate, I assume because the computer thought I was going to roll the jeep. If I dumped the clutch and did a doughnut it would not activate. Just my experience
