Traction control probs
BertaNation
So recently I had new rear shafts put in my rear d44. While doing the R&R we found that there was a lot of mud that had gotten into the ebrake and tone ring area. After thorough cleaning and everything was back together I had an abs and traction control problem that led me to replacing the right rear abs sensor. It has now cleared up for the most part. Now while making a slow speed right turn from a stop my traction control light will come on and try to shut the jeep down. Any suggestions on what the problem would be. I will most likely go ahead and replace the drivers side also. Just wanted to get an opinion. Thx
2015 jku
Check the plug itself, if the red tab gets cracked or any part of it gets broken it won't stay connected all the way and cause what you're describing. My traction control and ABS light came on after hitting a bump and from making a sharp turn. Replaced the plug (wire side) and it fixed my issues.
