The "Mid Life" buy thread
Looking good Brandon! How do you fix that?
Not completely sure yet - I have 4" bump stops but probably need a little more - My ride height is set pretty low as we did not want to set it until I get my tire carrier on the rear. I'm also not sure what roll the timing rings play in the front as both springs are 250's - My guess is to raise my ride height a little and add a little more bump stop and lower my timing rings. or maybe limit my steering stops - to be honest I'm not sure.
Got it. I'll be interested to find out what you determine the correct fix is. I'm starting to think that this might the a good kit for me and hoping to get some help installing it so it will definitely be good to know once you've worked it out so I can do it right the first time 😄👍🏻
Got around to installing my 20" Light Bar for the bumper with EVO Bracket
NOTE: This bracket is made for the "EVO Pro Series Bumper" it is NOT a "Pro Series Bracket" Read the description carefully - This will work for my application on a Quarter Pounder Bumper but the mounting surface is NOT bent at 90* it is more like 100* However my winch controller is in the way so I used it in reverse.
Bolted it up and realized I am out of wire - so I will wire it up tomorrow :doh:
Looks good! Are you going to wire it to your fog light switch?
Looks clean Brandon, great work! 
Thanks
Nice!! Bright?
No I'm not so bright :doh: (not wired yet)
Looks great! When you get it wired let's see how bright it is. I really like the look of that.
Thanks, I will try but it is hard to show how well a light works with a camera but we will see.
The bracket is so clean and the bumper is so dirty.
I found this cool teflon spray that repels bugs - I only applied it to the bracket as a test to see how well it works - apparently pretty well! :cheesy:
Gave Eeyore some wax today - made an attempt to buff out the pinstripes, got all but 3 gnarly ones but it is nice and clean now:thumb:
“Most likely get it dirty again, anyway.”
