Strange noise from transfer case ... any clues??
TRAILN
hi guys - any clues as to what this might be -I put a screwdriver up to the transfer case and the noise seems to be coming from there (2008 JKU Auto Petrol). Well, i tried several spots with the screwdriver and this was the loudest spot.
The rattle/knocking sounds seems be occur once per wheel revolution.
Yes, the boot on the front driver shaft is worn / slightly ripped, but it not touching / fouling anything at this low rev speed.
The Jeep is in 2H with the front up on axles stands, allowing me to rotate the wheels by hand.
http://www.youtube.com/watch?v=NMfNr7f3xYA
cheers
thanks for the response. yeah, it's a stock drive shaft. what is it they say about Jeeps -- Just Empty Every Pocket -- oh well, another weekend project for me LOL. local guys here reckon replace it with a Tom Woods - about AU$700 plus fitting (which i believe i can do myself)
I'm assuming your in Australia? If I recall they are super strict about lifts and keep you below 3" correct? I would save your money and buy a used JK drive shaft from another jeeper or junk yard. Stronger than a 1310 and a ton cheaper!
