Speaker Problem with Roll Cage
rcastell69
Question I am sure many of you Have a Roll Cage I have the Poison Spyder one in my 2010 Jeep JK now I have a Problem with my Driver Side Speaker well as you know you have to take apart the Roll Cage to get to the Speaker has anyone made a Modification so you can get to the speaker from the Front ? If so maybe a Picture and Explanation I was going to cut out the front of the Dash Lower and make a Speaker cover so its easily accessible.
Have you tried pulling the kick panel under the steering wheel to see if you can get access through it? Don't think you can pull it through the hole but maybe you can get to the wiring.
Have not tried that will do and let you know I thought there has to be another way and someone else has had this problem thanks
