Rubicon E-swaybar disconnect
Kenthejeepguy
Like so many others, the e-disconnect swaybar had water in it and is toast. (happened twice before and was replaced under warranty, but now it’s on 𝗺𝘆 pocketbook.) 2011 JKRU BTW. 56k miles. I was looking at the EVO air-powered disconnect, but then I tested my old one. The motor still works, and reverses when the leads are changed. Has anyone hardwired a switch to theirs? A momentary DPDT switch ought to work. Crazy idea?
Can't be momentary. Need constant power to hold the bar unlocked... It springs back to locked once power is removed.
I would go with the Evo manual disconnect. By far one of the best decisions I have made. Granted you do need to remember to connect it back when you get on pavement otherwise it will be fun.
Haha ^^ fun is right.
I second the manual. If I had the opportunity to disconnect more than I do I'd consider the air version but the manual is stupid easy.
I live close to lot of trails and use my disconnect frequently. Don’t think it requires constant power, as the motor turns a screw, then turns off. If direct wiring doesn’t work then I will use an air powered disconnect so I don’t have to get out in the mud and dirt if needed.
Besides, the manual disconnect is about $100, and I can get an air power disconnect for about $200. For a hundred bucks I think it’s worth the convenience.
IMO anyway
I'm starting to have the same issue. Very annoying. I'm gonna drop it off at the dealer when I get back from my trip in Tahoe.
