Rotating Tires x5?
Doplar
Hello all,
I've owned my jeep almost a year- and I'm nearing 15k miles. I was thinking about rotating my tires. Should I, or can I rotate my 5th (never used) tire? At some point when I buy new tires I don't intent to keep the size that came with the jeep. I hope to be ready for a lift and some new 35s.
I appreciate any insight. I'm still new to doing my own jeep upkeep.
thanks.
Jeep 2014
Anvil
No extras (yet!!)
Hello all,
So you've gone 15k without ever rotating????
Or are you asking if you can/should now rotate in your spare even though your other tires have 15K on them? You should be rotating all tires every 3k-5k depending on your preference.
My :twocents: but at 15K, your likely about 1/3 through (or more) the general quality lifespan of the stock tires. I wouldn't rotate the spare in at this point. If you've never done a rotation, you should ASAP as no doubt you'll have uneven wear.
edit: overlander beat me.
You haven't rotated your tires in 15k miles? Yikes. I wouldn't rotate the spare at this point.
yikes! yea if you havent rotated in 15k its pointless to rotate in your spare now like overlander said. i rotate all 5 of my tires with every oil change (3k miles or so). i would just rotate 4 for now and when you get new tires do all 5
Eeek! You change your oil every 3K??
I rotate tires and change oil at 7k. which will be this weekend, I just rolled 16500 (did my first oil change to full synth at 2500 to get the break in oil out)...
i used Mobil 1 syn 15000 miles, i change it every 10,000 miles and rotate tires every 4 to 5k
Wow. now I'm glad I asked. Yea. I haven't rotated them at all. I've been getting my oil changed every 3k (the dealership gave me 8 free oil changes over the 1st 2 years).
Ok so at this point I will not rotate in my 5th tire.
When I get new tires, if i rotate them every 3-7k that should be fine to work all 5 in.
This is why I'm happy to be part of this community. I appreciate all the knowledge the members share.
thanks.
thanks.
I would say more like 3 to 5k! 7 might be to late to fix a problem you could see during rotation!
When I worked at the stealership we recommended rotating tires every other oil change or roughly every 6k miles, do a re-balance every other rotate or every 12k miles roughly.
