Rim width help!
dannymalkin
I currently have 255/75r17 KM1s with stock rims. I want to get the Pro Comp 5129s in 17x8.5
I know that they will fit and understand rim dimensions, I was just wondering if I would be more likely to pop a bead while off road? Especially if aired down or not?
Here is a picture I found online pretty close to what I'm asking about, it looks like there is space where the bead is seated on the rim. Thanks!
Sorry I edited it now. I am asking about the bead becoming unseated while either aired down or under normal pressure.
Yes,
The 8.5" width rim is on the wide side for a 255/75r17. This will cause you to unseat the bead MUCH more easily. On non bead lock rims I prefer to stay on the narrow side when selecting wheel diameters.
as mentioned it will be easier to pop a bead. i basically run a "poor mans beadlock" because i run a 12.5" wide nitto on 8" wide wheels. it makes it really easy to hold the bead when aired down
whats a poor mans beadlock? :thinking:
i'm looking at putting some 35x12.5's on to some 17x9 steelies
