Red Loctite
07streetbobrider
When my tires/rims come in I'll be taking off the spacers. I used one drop of red Loctite on each stud. Do you think I'll still need to heat them up to remove?
I just removed my spacers that were installed with red loctite and they came off no problem without heat. I thought it was going to be an issue too but it wasn't.
Just took mine off last weekend and I used a lot of the red stuff. Except for 2 nuts, they came off without no problems. On the other 2, a longer breaker bar did the trick. When I took them off, I could still smell the loctite after 2 years.
depends on the red Loctite - I discovered there are several types of red Loctite threadlocker, one does require high heat, I used a high temp heat gun to get it soft enough to break free.
