Rear Shocks Relocation
changyangjlurd
I have a 2021 EcoDiesel on coilovers, what are the options on relocating the rear shocks to gain more clearance? My shocks are set somewhat low that I tend to hit it quite often. Anyone know if there’s available kit out there or any suggestion on how to properly relocate it? Maybe rear shock towers and lower shock relocation bracket? Thank you all in advance.
For pretty much all of the bolt on kits that I’ve seen out there, they all essentially mount to the stock shock mounting location on the axle. Your other option is basically making custom brackets to move everything. Looks like you added some skids plates that appear to be working for ya so I say roll with it till you decide on going completely custom. What kit are you running?
changyangjlurd
I’m running the Accutune 2.5 coilovers stage 1 kit with Rock Krawler adjustable mid arms. Yeah, it’s unfortunate that the stock rear shock mount location on the axle is so low. I would not mind going custom to gain more clearance if only I can find a trustable shop to do it.
Well I really wouldn't consider that a deal breaker as some rubbing on a skid (which is dam near the same as your lower control arm mounts anyways) isn't a huge deal or at least for most. I'm 30 minutes away so feel free to stop by, hang out and we can take a look (y)
