Re-Gearing
Jeepin7
Hello All - I just put 315 70 17 BFG KO2’s on my JLU Rubicon automatic. I have a 4.10 gear ratio, and seems to be acceptable. Any thoughts on re-gearing to 4.56 or 4.88 would be appreciated. Thanks
I had 315's BFG's KO2 on my 2017 JKUR with 4.10 GR loved it. I just added 37's with the 4.10 gears, just ok but miss that speed with the 315's. The jeep still goes ok but I am going to 4.88s next month.
That’s how I’m feeling with driving on 4.10’s and 315’s too. I am also wondering if by not re-gearing, will I be causing additional wear on the engine, transmission, etc.? Seems great to drive, and not really wanting to spend $1,800-$2,000 to re-gear, if not needed. Thanks
Agree I think my 37's are stressing the power train. so its getting 4.88s, but think 4.10 and 315s are a great match. Your BFG are a lot shorter than you think search in this Forum
The Ultimate TRUE TIRE SIZE Database​
It has some cool stuff
Happy Trails
Your options with the carrier on the JLUR are 4.88s or 5.13's. 4.88's are totally fine to handle up to 37's and you will get 8th gear back (I did Yukons, they have a complete kit). If you think you're going to go larger then 37s you might want to look at 5.13s but you will lose some fuel economy for sure. Sorry if I'm assuming you are automatic trans :)
315s on a JL Automatic with 4.10s is fine. I think regearing with that combo is unnecessary.
I would agree with what he said, I kind of just jumped into the solution without reading your initial post. 315 70 R17's depending on manufacture are slightly larger than 34'' tires. The 4.10 gear ratio should be sufficient, they are just barely larger than the 33'' tires that come standard with the JLUR. I went with 37x12.5xR17's, also the KO2's and they are heavy enough to cause loss of 8th gear most of the time that a re-gear was needed. I would run it for awhile and see if it will hold 8th gear at highway speeds. You need to make a change to your vehicle display to show what gear you're in.
Did you calibrate the PCM for the taller tires?
That will make a difference in how it drives.
I noticed a difference going to 4.88’s on my JLUR with 37’s and a decent amount of added weight.
honestly for the cost of a regear you’re not going to get enough out of it coming from the 4.10’s for that small of a tire change
Yes. I did the PCM for big tires, and feels good. I agree with what I’m hearing. I do not think I’ll re-gear, unless I go bigger. Thanks all
I think if your staying with 315’s you shouldnt spend the money on re-gearing. I think it would be a waste for the added benefits. Now if you go up to a 37” tire you’ll definitely want to. 5.13’s and 37’s is the sweet spot for a jk.
I went to 37s and 4.88s not long ago. 4.56 would have been the numerical (rpm) equal to 4.10s and stock 33s. I was geting a lot of recommendations to go to 5.13s. But I like the engine loafing around at 65-70 mph.
From what i've read about those with 35s and stock 4.10s is that 8th gear is a rarely seen thing. I would think 4.56 would be the sweet spot for highway/street. Off-road won't change much, since the 4:1 transfer case is more of a mathmatical influence. My understanding is that you regear for street focus and that it has little impact on the off-road capability, unless you are going from really tall gears to really high multiplication gears.
My Jeep sees 8th gear without any problem. Seems like 4.10 with automatic with large tire flash to pcm with 315 70 17’s is good.
