Quieter ride?
jbg_132
I know this might not be changeable, but does anyone have any advice on how to make my ride more quiet? I have a 1994 YJ. I’ve already sprayed raptor on the inside and put a carpet kit, and I’ve also gotten new door seals; I wondering if there’s anything else I can do for it?
What type of noise are you getting? If it's road noise welcome to owning an older jeep. If it's wind or whistling check all your seals. Doors, tops, windows, windshield. A cracked gasket or brittle one causes A lot of random noise
I put carpet on the inside of my hardtop and it not only helped with being a quieter ride, but also helps with insulation.
Maybe a revival but none the less, I would go dynamat. I haven’t had a chance to do it to my 94’yj yet but I figure if you rhinoline the whole tub, dynamat and carpet you should be set. My buddy used dynamat on his dodge and I was impressed by the result. His truck is LOUD. He got in it a bit when I was helping him move and we held a conversation like we were sitting in a library. Keep in mind his truck is a 850hp Cummins, 8in straight pipe, compound turbo, cam etc etc so by no means is that thing quiet[emoji23]
If you have a hardtop I would also check ALL fasteners and make sure everything is tight and splurge on some universal top fasteners. Made a big difference in mine. Maybe some weather stripping between the top and tub as well
