PSC squeal
Atch
I just installed and tried out my PSC hydro kit for the 1st time. I must say it handles great but when I'm at full lock or wheel starts to bind a little it sounds like 2 monkeys having sex under my hood. Has anyone else had any issues with this?
Hightower
I gave my monkeys a pack of Lucky's and some Kentucky sour mash and haven't heard a thing in weeks. Lol
Driver driver GAS!
WAYALIFE mobile app
pvanweelden
Those monkeys were making my squirrels jealous all day, the one has stamina :thumbup:
Sent from my LG-C800 using WAYALIFE mobile app
Atch
Driver driver GAS!
WAYALIFE mobile app
Maybe I'll give this a try after I talk to PSC on Tuesday! 🐒🐒
HDGasser
I'm more concerned with the fact you know what monkeys having sex sounds like...:bleh:
optimus prime
Psc
I installed a PSC system a couple of months ago and after a short while I had a huge problem with belt squeal. I thought I could resolve the problem with a smaller belt and the issue did go away for a few days but then returned. After a while I called PSC and explained what was going on. I was asked if I had a steel or aluminum bracket. I explained that I had a steel bracket and was told that they where having issues with the steel bracket not being strong enough and deflecting under heavy load and that the new aluminum bracket solved the issue. A couple of days later in ad the new bracket at my door and it became obvious why the aluminum was stiffer. It was made of 3/8 thick plate and was a way more substantial bracket than the steel bracket. Once it was installed and the correct belt reinstalled the issue disappeared and I've haven't looked back since.
I do have to say that the service I received from PSC was excellent. They did everything they could to resolve my concerns and get me on the road again.
Cheers
Grant
Atch
I've spotted the problem, my PSC high volume pump stops when at full lock. It's causing a lot of resistance on the belt. Hopefully I can get the pump replaced quickly to resolve the god awful noise.
SaddleTramp
Tie Rod?
Sorry for the thread drift, but getting ready to install a PSC kit, have you all upgraded the stock tie rod when you installed the hydro kit? I'm just trying to get everything ordered at once, be somewhat proactive and make sure I have the correct brackets. Thank you for any help.
Atch
I currently have the stock tie rod, however I just ordered the synergy tie rod. The PSC kit works fine with the stock tie rod.
CRAZYCASEY
Do not run the stock tie rod it will completely fold on the trai.
Atch
The squeal was a result of reusing my stock belt, it must've been stretched a bit too much. I installed the supplied belt and all is quiet.
JeepFan
The extreme kit comes with a bigger idler pulley and a smaller than stock pulley on the PS pump. The supplied drive belt is a Goodyear 4060887 Gatorback Poly-V Belt which is slightly shorter than the stock belt.
