Need some advice on my DTD lift. (pic heavy)
My Jeep is leaning to passenger side almost 3". Do I just keep tightening the pre load on that side?
Passenger side
Drivers side
Passenger side turn buckle
Drivers side turn buckle
Rear pre loads are pretty even
The spring rates on a coil over like this will be on the soft side and will feel the effects of things like your gas tank more. In short, yes, I would adjust your passenger side coil overs to help compensate for the lean. You can also set your sway bar links on the passenger side a bit taller too.
