Need help real quick
red84cj7
I finally bought my Synergy drag link and I'm in the middle of the flip. After removing the old drag link, in the hole in the knuckle there appears to be a spacer. I have attached a picture from directly above where you can see the gap in the spacer, and one showing the bottom of the knuckle where you can see the spacer sticking out. This isn't normal is it?20190727_111050.jpg20190727_111124.jpg
Sent from my SM-G960U using WAYALIFE mobile app
Can you push it back up and make it flush? Spacer should rest on top of the knuckle with a flange from the ones I’ve seen. I’ve never installed a synergy though.
I finally bought my Synergy drag link and I'm in the middle of the flip. After removing the old drag link, in the hole in the knuckle there appears to be a spacer. I have attached a picture from directly above where you can see the gap in the spacer, and one showing the bottom of the knuckle where you can see the spacer sticking out. This isn't normal is it?View attachment 331542View attachment 331543
It’s normal if it was “over reamed” or drilled out to accept an aftermarket end.
It was the factory drag link installed from the bottom. The Synergy kit requires the hole to be drilled to 7/8". I'm guessing I just need to try to knock it out because how do I drill that without the drill bit grabbing the gap in the spacer and mucking up my $40 bit?
So take it out. What size is the hole without the spacer?
I was able to knock it out. Just never saw that in any of the videos I watched so my first thought was, oh here we go, this shit always happens to me. Simple jobs are never simple for me. Anyway, thanks for the input guys.
Only to find out the hole is already 7/8 so the good news is no drilling. The bad news is I wasted $40 on a drill bit I didn't need. Anyone need a 7/8 drill bit?
I'm gonna try. Receipt says 20% restocking fee. I may be able to sell it to someone in need for the same difference. I'll see what my guy from Synergy says. They're an hour away from me and I got a tour of their facility yesterday which was cool. I'm hoping to buy their tie rod soon.
Return the drill bit.
Damn, I would’ve bought it from you two days ago but I just ordered one from Amazon for a totally different reason
