MOLLE PANEL REAR DOORS ?????
kengeroo
wanting to install custom molle panels over the rear seat window,, does anyone know if it would be safe to drill and rivet in rivet nuts at the blue spots.... and there will never be passengers in the rear as all the seats have been deleted and area has been converted to storage
Edit
All reactions:
44
7
Like
Comment
Fuck it… You only live once dude, just go for it.
I don’t see any reason why it wouldn’t work, except not being able to clean the inside of the glass after. I suppose you could just vinyl the inside (or outside) of the window before bolting the panel over it.
Should be fine, probably want to black out the windows first look better and keep your gear from heat/sun damage. Also careful anything too heavy or sharp, on a rough trail it may bust the window out. (Batteries, tools, magazines, etc.). If that’s they case May want to put a sheet of PLA or ABS between the molle and glass. Could 3D print something.
