Maybe a dumb question
Ah2014jk
Ok so here is a simple question but I need some help. I had to get new brake lines for 2 reasons. 1- mine where to short and 2- because of them being to short I damaged one side pretty good. The only ones I could find right away were a set of rubicon express stainless ones ( still to short ) but my old ones didn't look safe any longer.
The question is where the hell do you mount their bracket ?? It sticks out pretty far and will hit the sway bar on up travel. If I mount it way near the top of the frame then the lines are way way to short. I am pretty sure they are only 22""
Any pics of where these should go or even any pics of the sway bar at full stuff would help a lot as maybe I'm over thinking how far up the sway bar will go
Help😾
They should have came with little brackets with clips, but I would still get a longer set add relocate them using Frank's write up, I did mine like this to avoid the sway bar catching the lines.
