little help
YAEGER83
I was just reading up on the budget boost kit for my jk, and it says i need a aftermarket wheel with at least 4.5 inch of backspacing. Just so happens i already purchased some rims with the size of 16X8.5 5-127 -6MTB . will that work? if not, what wheel spacer should i buy? thnx!!!!
Sorry, not sure what the back spacing on a wheel like that is but, assuming it doesn't have 4.5" or less, you will know right away as your rear tires will make contact with the sway bar link ends. if you do need wheel spacers, i would recommend that you get a set of 1.5" spidertrax.
It will fit / clear ....Those are the same specs on the rims I am currently running. They have a 4.5" BS....
