Lift parts
MSJKU11
Looking for a couple pieces if anyone has a used set they aren't using. This is for a 3inch lift.
Front and rear trackbar relocation brackets
Extended brake lines
Extended sway bar links
Sent from my SM-G965U using Tapatalk
I have rear brake line brackets if they would work for you
Thanks for the offer. I didn't think about brackets. No issues with a 3 inch lift? Any added benefit for going straight to new extended lines as far as articulation goes?
I believe front and rear don’t make much of a difference since some lift kits will have you swap the front links to the rear...
That's true. I see they were quick disconnects, didn't know if they were different somehow.
They drop the mounting point 3” but stainless brake lines are cooler [emoji106]
You can have them if you want them
