kinda concerned
jyazz06
just changed my spark plug s gapped at 50 then drove about 300mls then had shake at idle & then check engine came on said number 1 cylinder misfire regapped plug then test drove again , felt little shake that is a little noticeable what can cause small idle shake has 70,000 mls
jyazz06:sigh: like to know asap thanx
May not be the plug. Can you swap wires with another cylinder and see if the problem follows the wire. You may have stressed the lead when you pulled it off the plug the first time. If you swap wires and problem doesn't follow then swap plugs see what happens.
replaced drivers side wire s still a little shutter ,going to replace pass side tomorrow when it stop's raining thanx
change all the wire s roar s like a rubicon again thanx .
jyazz06
