Jku rubicon auto shift issue
fengger
Need help here:
After running wild in Johnson vally for a whole day, my four door 2016 automatic rubicon is driving with 1 or 2nd gear only. What could possibly have gone wrong?
I need to take off all the skid plates before the dealer can take a look at her. (Otherwise 600 dollars surcharge). Anybody who has been in the similar situation before? Thanks and happy new year!
with the lift you have, it's possible you pulled or chaffed (causing grounding) an ABS sensor wire.
I'd check the abs sensors and wires to make sure they're all good.
Thanks for your advise. My drive side abs sensor was bad befor and I had no gear shift issues. I then I had it replaced before going out. After returning from Moab the abs light was on again but had no problems with the driving.
Anyway I will fix the sensor again and see if his problem will go away. Thanks
did you check to see if it has thrown any codes? whoops already asked. you could also disconnect the battery for a bit and see if that helps.
