gingerchocolate
I did a search here and can't find any information on adjustable rear spring mounts.
Is this something that is necessary?
It is more necessary for a two door when you adjust the rear pinion angle for a higher lift the stock spring perches will be tilted backward more causing excessive bow in the rear springs, these will center your coils back on top of the axle
I was thinking about getting these a as well, my 2 door has a bow in the rears as well, only thing that i wasnt to over the top about is that the old mount is cut off and its just u bolted on.
You seem to be destined to come to Ohio and have some welding work done![]()
I plan to do the weld on spring mounts once it warms up and I can work outside, those can be either set in "stock" or a "stretch" spot :thumb:
I really don'y know much about the JKS ones other than them being a bolt on. I am tentatively planning on using the Artec ones when I stretch the 2-door. They are weld on and half the cost. I suppose one thing nice about the bolt on is the ability to adjust then easily if you change lift heights.
Thats the ones Im gonna use, just couldnt remember the name. Well thats if I evey start to actually use my welders lol.
Oh hell I'm just gonna get coilovers to bypass this altogether lol
That's the thing I like about the jks ones is that they are adjustable. I could get them now to adjust the bow I have and then when I go higher I can adjust them again.
Thanks for the replies guys.
I think I'm going to go for it. I'm just not sure if it will work with the EVO Trackbar Bracket. I might end up having to use weld ons. I'll report back with how it goes when I get them.
