Still not convinced?  Let's take a closer look at how things work.  When you look at the bushing of your track bar or control arms, the metal piece in the middle where your bolt will go through is called a "crush sleeve".  AS IN, it's designed to get pushed really really hard from either end.  The purpose of your bolts and nuts is to provide "compression" and cause your mounts to act like a vice by clamping down really really hard on the crush sleeve.  The crush sleeves is NOT supposed to rotate AT ALL when installed correctly but rather, the bonded rubber bushing will twist around it.  Of course, if you have a polyurethane bushing, heim or other aftermarket joint, the bushing will rotate around the sleeve or misalignment spacers - again, there is NO movement around the bolt and therefore, shouldered bolts are NOT necessary.  This is the reason why bolts are rated for "torque" and NOT "sheer" - the value of compression strength is all that is necessary to hold things together.  Don't believe me? Place a pencil between your index finger and thumb and hold it in the air.  Why doesn't the pencil fall?  I mean, there's no bolt going though your finger and thumb to hold it in place.  Pinch it harder and it will even take effort to move the pencil around.  Imagine that - compression alone made that possible. :crazyeyes:
If you really want to spend money on your Jeep, invest in a good torque wrench and use it as a part of regular maintenance. :yup:
