nmwranglerx
Long story short, I was trying to get a rear adj control arm adjuster unseized and ended up having to remove my passenger rear axle shaft. Shaft needed some coaxing to remove but upon removal I found that the bearing had moved. I stupidly tried to put it back together which caused damaged to axle tube end (see pic). Is the silver damaged part in pic actually part of the axle tube. Any ideas how this could be fixed or what it might cost? Any ideas how I might get jeep towed with only 3 wheels? I'm worried further damage will occur if I try to reassemble to put tire on.
