You can still easily overheat trans fluid with 15 oil coolers if you crawl in the wrong gear. They simply increase capacity, but at slow speeds/fluid coolers without active ventilation (ie radiator fans) don't really do much. Besides, the 2012+ JKs have a built-in decently sized cooler, so again, if you're getting hot oil, you're in the wrong gear. Now, if you have a prior year JK, then you don't have a cooler, but again, the CAUSE of the temp spike is the heavy load, and the heavy load is generally caused by being in the incorrect gear when climbing steep grades for extended periods.
