If you look and compare the working bits of a farm jack with the HI lift, you can see the quality. All Hi Lift moving parts are serviceable. The Farm jack has been known to bend under heavy pressure,
The Hi lift has an assortment of accessories that can be used with it.
The use of the jack is pretty simple and uncomplicated if you follow the guide lines.
Never stand in front of the handle. Do all your work from the sides.
Put a brick or something behind the wheel in case of moving backward.
Its a good idea to have Hi-lift jack points forward and rear of the vehicle.
Your vehicle will shift to the side if you lift a vehicle that is standing at an angle. You have to compensate
for this.
I have used this jack to lift my vehicle out of a hole, put a rock in the hole and drive out.
You look after your jack, it will look after you.
I have used mine for compressing a door, you can also get a winch adaptor Kit and a wheel kit.
I had rockslider lifter some xxxxxxxxxxxxxxxxxxxxxxxxxxxxx time ago of but disappeared. I am looking again, might have to import.
See pic below. I found this on the net. This is what works well , provided your slider doesn't bend.
