They look easy enough to install but try to do a little write up if you can?
I installed both the king 2.5 bumps as well as some 2.0 bumps in the rear using the Evo Brackets...Thanks Drew for taking care of me.
The front install is easy. The directions from king are horrible.
Basically remove the spring and measure 3" from the bottom of the stock bump mount after you remove the factory urethane bump.
use some blue tape as a guideline going around the round tube.
I did the passenger side first using a 4" cut off wheel and it was a pain to cut the rear portion. I have two sawzalls but I didn't have any straigh/good blades so I just made it work and it took some time.
I bought some blades the following night and was able to do the drivers side in probably less than 30 minutes from start to finish.
You will need to sand the inner part of the upper tube to get the blue ring to seat properly. Thread on blue billet deals and make sure you get two solid threads on the top.
I than used a screw driver and a dead blow to tighten the bottom collar and followed that up with blue locktight on the set screws.
reinstall the parts you removed and enjoy.
FYI only one of my bumps came charged
:banghead:
I have access to a nitrogen station so it wasn't a big deal but it could be for some people. I found that I like them at about 110 psi both front and rear
