I'm rolling with this setup. Yes I am happy with my decision to stick with 37's for now. I am planning on 40's but not until I go with an LS. And from the research I've done my 5.13 gears will be a great combo for 40's and an LS. I have to many other details to button up before I jump to 40's.
Needs
Hydro assist
Heavier duty rear tire carrier- my poison spyder brawler 2 is just barely working with the 37x13.5 with atx pro chamber 2. Probably just do the evo carrier.
Go fast suspension (evo)
I installed the evo rockstars to gain ground clearance at the shock mounts. I would recommend doing the same. But not necessary.
I did not have to change any of my springs bump stops etc. I went from a flipped drag link on a d44 to a standard bottom mount drag link and with the raised knuckles of the pr 60 I am exactly the same angle and location at full bump. About a 1/4" from the frame. I also had to do a little bit more trimming on my front fender wells. The extra width of the axle caused that, but nothing crazy.
Sent from my iPhone using
WAYALIFE mobile app
