Hard Core ProRock 60/60 Axle-Set Question
gmb425
I've been saving up and would like to purchase a Hard Core ProRock 60/60 Axle-Set. I have a Rock Krawler 2.5 Stock Mod so basically I have no aftermarket control arms. At this time, I cannot really afford anything except the axle set (and new wheels with the new bolt pattern). OK, on to my question... because I only have enough money to purchase an Hard Core ProRock 60/60 Axle-Set, is it possible to install it with my current setup. I'm currently at about 3 inches of lift. I will most likely stick with 35's until I can save up enough money for 37s. As far as suspension goes, I would like to run the EVO Double Throwdown System Package in the way future but have heard that there are some clearance issues when used with the Hard Core ProRock 60/60 Axle-Set. So in summary, I would like to know if I could purchase the axle set and install with my current setup. And wanted to get anyone's opinion regarding the possible clearance issues. Thank you for your time.
GRBG TRK http://wayalife.com/showthread.php?38800-Garbage-Truck-(GRBG-TRK)
You'll likely be fine. I'm sure there will be something here or there when it comes install time. obviously you are going to need new driveshafts as well, but call dynatrac and talk to them. They are beyond helpful and super knowledgeable.
Okay, thanks. Hopefully they stumble on this post but if not I will definitely give them a call. Every time I stop by your profile, your Jeep has something bad ass going on. Very nice [emoji1303]
Well thanks man I appreciate that.
I wouldn't count on them finding the thread, they are pretty busy over there, just call and ask for Steve or send him and email. Guy is so helpful and will talk to you about all your specs and give you a straight up advice.
Also you only need 50% down to start an order so just get your order placed and you can start your 8 weeks of anxiety and planning ahead of you.
Also, I cannot find the post Eddie made regarding the EVO Manufacturing Double Throwdown Front Coilover System JK EVO1010-60 compatibility/filament with the ProRock 60. Do you know, off the top of your head, what the topic was called?
