webejeepin
I'm at the point were I want to upgrade from the TF level kit to a 2.5" coil lift, either OME, TF or RE. My end goal with my 08 is to continue with the 33's, and add the aftermarket bumpers...hence the want for the 2.5 coil lift. (DD 120KM per day 5 days a week, 10% light trails, nothing extreme)
Willing to build as I go as like with most budget comes in to play, so I'm ok with doing just the coils and shock extensions, then upgrade the shocks, the finally bumpers.
I've read over and over the FAQ's and Install sticky here many times, watched the many youtube videos (TF does a great job)....however, there is one key part of doing the install myself, and I have yet to see a video that shows the lowering of the axle after the shocks and sway bar links are removed. My concern is with the coils, and the possibility of them letting loose and someone getting hurt.
Do these coils just 'fall out'? Or is there still some 'load' on them?
I'm a mechanically inclined kind of guy, do all my own fluid changes, breaks ect...but never wrenched on suspension parts before. I'm 95% confident I can take this on myself, and willing to invest more $$ in tools, IE a impact gun.
I've actually gone to the extent of doing a mock install...making sure I can get the Jeep high enough, and seeing how to reach each nut and bolt for access/clearance as you lie on your back, or kneel on the garage floor.
Being an 08 and exposed to the wonderful world of road salt...I would expect a good bath of PB Blaster and WD-40 will help.
Any advice from the experience from the Wayalife community on the spring danger and vote of confidence to do this in my garage would be great. Local 4WD shop wants $500.00 for the labour to do this.
Thanks!
Thanks!
