Exhaust flange
Joeyd94
Help!!! One of the bolts broke on my exhaust flange right before the cat giving me a small leak! Anyone know what size bolt and nut I can replace the stock ones with?!
Really any size that will fit thru the bolt hole and give you enough threads for the washers and nut will work. Just remove the broken bolt and try and get close with a new one
All of mine ended up rushing out and breaking. If you get in there with a punch you can push out the captive nuts and then you a nut and bolt with some washers. Next time they sieze up just cut them off and put new ones in.
