EVO bolt-on with 35's?
BBrown626
Looking to keep just 35's for a while so I only want 3" of lift. What sort of uptravel can I expect with this kit set at 3" of ride height? I don't find specs form compressed and extended length.
Are coilovers a significant improvement with 3" of lift or not worth it?
I have two leaking Bilstein 5100'ss on the back that I need to replace anyhow, so I'll at least upgrade to a rebuildable shock from Fox or King.
thank you.
I do believe that the coilovers go down to only 3.5" lift and the ride quality is what you'll get from switching to coilovers and a lot of travel. I could be wrong though
Ride quality on and off road will be increased significantly with EVO bolt on coil-overs. The articulation you will gain is great. Your 35”s will be fine.
GO FOR IT! :thumb:
I have the bolt ons. You can adjust them from 3.5 to 5.5(if you are running light and w/o doors). 3.5 w 35s will work great. I'm running at 4.5 with 37s. The ride on road will impress you.
