Enforcers Unite!
The rear EVAP skid plate needs to be moved over or the EVAP needs to be relocated.
I looks like I can elongate the holes and slide it over about 1/2" and that should give enough clearance. Not sure if rock got up there, think it actually made contact.
So is a front and rear drive shaft typically needed with the Enforcer? Sounds like a common problem. Thought you only needed a front
When you install the lift just Cycle the suspension pay close attention to driveshaft clearance. I didn't really pay attention to driveshaft but I did notice the rear brake lines and did that modification. No 2 jeeps are identical so just inspect everything
This is not the first time I heard of this issue when swapping to a PR axle, but as you do not have adjustable uppers, there is no way for you to move the axle forward. Is it something close? say, running closer to 4° caster would fix?
I'm contemplating buying adjustable uppers. Right now I have the lowers as short as possible, if I extend them I thought my caster would increase, before adjusting I put my protractor on the top of the c and it read 9, once it shortened them it read 6 and the alignment shops read out showed 5.1, this is the lowest I could get it, am I wrong about this? Would buying adjustable uppers help me fix the issue?
I'm also looking at the JKS Jspec 3.5" lift. Comes with Fox Performance Series shocks. Can anyone comment on their Enforcer lift vs that lift? One difference I know is that the Enforcer is a linear spring and the JKS is a gradual spring. Never ridden in either though.
I have the enforcer and really like it, if you are interested trail jeeps has each one on a rig and wild let you drive both to make an informed decision. I have heard good things about the JKS but I'm super happy with my EVO lift
I installed the Jspec on my Jeep and have only good things to say. I can't compare it to the Enforcer as I have no experience with it. But the ride is much better than stock. I haven't been able to test it off-road yet but so far I'm very happy with it. I paired it with their Jflex front LCA's and drag link flip. My only complaint is it comes with brake line relocation brackets instead of extended brake lines. But that's easy enough to fix and pretty cheap as well.
This ^^^^^
Went out to check a little flex since I got the 4" enforcer installed. I didn't have time to disconnect front sway bars but when I was backing down to get a better angle I heard a noise under the jeep. I know I need a new front drive shaft with this lift on a JKU. But I now will need a new rear drive shaft. View attachment 195638
Any ideas how long this will last? Ithe looks like it hit evaporated canister.
it will last for a bit. What I would do is see if you can find another oem one to swap in. Before you do tho move the evap skid over or relocate the evap.
I am looking for measurements for a 2 door with the 3" enforcer kit....coil spring and shock please.
Thanks in advance!
I don't have the measurements but when Hinrich ran it he yielded about 3.5" of lift and that's with a semi heavy set up
Thanks man! I though it was a tad more. You rig looked awesome on Moab thread....I hope you are not texting and driving!:cheesy:
Kind and helpful forum-folk of the Wayalife Enforcers Unite Thread....please lend me you ears (eyes?).
I was running through a parts inventory of my 3" Enforcer kit and noticed that I was missing "Shock Mount Hardware". I have calls into Trail Jeeps and Evo to look into this for me...but I am just trying to better understand what I am actually missing from the package. From my best (and mostly limited) knowledge, I cannot find any reference to "Shock Mount Hardware" in the instructions, other than in the parts list. I was under the impression (which could very well be incorrect) that I was supposed to use the OEM shock bolts when putting my new shocks in (Rancho 9000xls). Perhaps this "Shock Mount Hardware" is the shock relocation brackets? I believe it was mentioned earlier in the thread that those brackets come with the enforcer kit standard now (please correct me if I'm wrong)?
In any case, if this "Shock Mount Hardware" is indeed the relo brackets, it seems like I may be able to just run the shocks in the standard locations for now, then throw the brackets in later? (Unless of course "Shock Mount Hardware" is something totally different and I'm just a complete idiot of course).
Shock mount hardware would to me, would be the hardware for the relocation brackets. If you did not pay for extended shock mounts, you reuse factory hardware. Unless this is new? I reused my shock mounting hardware and don't have any problems. :thumb:
