Drag link hitting frame at full droop
Like said more bumpstop. ORE had one Jeep where they notched the frame to clear it, but more bumpstop would be an easier option.
Here's another thread too:
https://wayalife.com/showthread.php/36587-Drag-link-flip-Q
And another:
https://wayalife.com/showthread.php/46577-Frame-notch-on-EVO-high-steer?highlight=notch+frame
That's with a high steer kit only. Not the factory drag link. It's not needed with the factory drag link.
Yep, three inches (pucks) of bump. I'm contacting the bump stops as I'm hitting my drag link.
3.5" lift and 37s.
I don't know if it's the same on the 60 but are you running the bumpstop spacer?
Dynatracs spring buckets don't have the built in bumpstop, so your 3 inch bump is effectively a 2 inch.
That could be your issue.
