I've been looking at the evo enforcer lift and was curious what a drag link flip is. Does it help your steering or something?
when lifted over 3" your steering can get out of wack due to the new height. in order to help return your steering geometry back to stock you need to do a drag link flip. this will get your drag link and trackbar back inline (parallel) with each other.
If you look at your steering now you will see the drag link attaches to the passenger side steering knuckle from underneath. The kit will "flip" the drag link on this end by attaching from the top. The kit also includes an axle side bracket for raising the track bar about 3".
Sooooo correct me if I'm wrong...you can use existing trackbar and no need for an adjustable trackbar right?
Correct. I still run a factory track bar on both my JK's. The relocation bracket that comes with the EVO flip kit will not only correct your steering geometry, it will help return your axle back to center and without the help of an adjustable track bar.
Thanks Eddie! I can't believe how EVO's kits are so easy to add on in stages. I think I found my future lift.
