Dome light & Radio Problems
hogtyed
Had to replace the TPIM. Now I'm having an issue with dome lights not coming on with door open. Also the radio stays on after the key is off and door open but it does time out and turns off after about 15 seconds. I have checked the door plugs but they seem to be alright.
I hear of many issues after TIPM swaps and why I still have rear doors that won't lock or unlock with the key.
Curious, was yours a dealer swap or thru aftermarket swap?
I'd check the connections make sure they aligned properly and look for any bent pins
Deff check for bent pins^^^^. I have had a few trucks come in where people replace the fuse block then have issues because they didn’t align it right and bent the terminals on install.
