Different castor angles.
steve_r2
Ok had my castor checked and have 3.7 Left and 5.2 Right.
Is this normal to have this disparity ? Is it the mean of the two that gives the overall castor ?
Or should it be back in the shop to be sorted ?
Your caster should not be different.
You have a solid axle. Something is not right.
Castor should not be different on each side. You need to have it aligned... if you don't have either upper or lower control arms you will need them in order to have it corrected.
Actually, your axle will be off from one side to the other from the factory but, not by that much - maybe a 0.2° difference at most. Outside of that, you have a solid front axle as has been mentioned and you would not be able to have a difference as great as what you are seeing.
