Daystar A-pilllar pod on 2013?
As mentioned above you need the 11-14 switch mount. Ruggid ridge has one and that's what I have
Sent from my iPhone
I just went back and forth with Northridge about this very same topic last week. Cozdude is correct; get the Rugged Ridge A-pillar switch. It comes with or without switches, too. If you want the one pictured, it is part number RGR17235.58. Don't forget to enter "Wayalife" I'm the coupon code for 10% off of the price and free shipping.
Anyone running this pillar with a sport cage? been wondering what that would be like if possible at all would be a waste to install the switches then toss it out if a cage was needed
Won't work with a sport cage.
Here is the panel in a 2008. Looks factory.
I have the same RR pillar mount with the RR switches. They are okay, but I've always wanted labeled switches exactly like yours. What brand are those? Do they stay lit continuously with your dash lights, or are you just showing them engaged?
Can you guys tell me what wire (location and color) to splice into for the dash lights? Hoping to find the wire that also dims with the rest of the dash. Thanks!
depends on what kind of back switch you have. i just bought 12 covers. driver side a pillar, passenger side, and shifter area. they will do text and images any way you want. during day for mine, just see it liek white writing. at night, it ligths up the amber color of bulb. covers are about 5 each. i didnt want to spend another 12 x 10 for new switches themselves but sharkey are neat. i tried painting the bulb but it didnt change the color
go to
www.otrattw.com
go to
www.otrattw.com
Sweet! Thanks a bunch bro. That was my next question, if I could just buy the $5 covers for my existing RR switches?
Yep, the switches in my pic are from OTRATTW. I installed them in a buddy's Jeep (look for the "Building of Meanst" thread if you want to check out the build). The lettering stays on with the interior dash lighting and dims with the dash lighting. The pictures come on when the switch is activated.
i have daystar rockers and when you order custome ones (called Contura v), they do need to be sanded down with a dremel on teh sides otherwise it's tight (like a virgin)
I've never really worked with switches before. How difficult would it be to just purchase the tops for $5 each and switch them with my RR switch top? Is that even possible, and if so, will I need to take the pillar mount apart to accomplish it?
Pulling the tops is quite easy and should not require you to take the panel off. Hard to explain in words, but the covers just basically snap on at the point that the switch rocks back and forth (I hope that makes sense). Go to OTRATTW and look at some of the pics of the rocker bodies. You should be able to see what I am talking about.
You shouldn't have to use very much force to get the cover off.
Yep, I totally understand what you mean. Thanks for the help. Being that easy, I'm grabbing a few of these right now. Thanks!
Sorry, I haven't tapped the dimmer on a 2010+ interior. Pre-2010, I tapped a dimmer wire going to the hot/cold dial for the heater/air. It's been a while, but I believe it was either a brown wire with an orange stripe or an orange wire with a brown stripe.
Hopefully someone will chime in with an answer for the 2010+ interior.
